I just installed an EAF auto focuser on my Meade Series 6000 70mm Refractor about a month ago. Did some research on the configuration on this and seeing a lot of different ways to set one up, depending on which scope you use.
Haven't had much luck with it, so last night I finally had clear skies so i played with it some. Failed miserably after 2-3 tries. Changed my Step setting to 50 steps, and changed one other Algorithm in APT. Seemed to do much better but still not solid ![enough...!
Hopefully you can see my image here...If so, based on what you see here, what do you think I need to change or adjust with my settings so I can get that optimal U or V Shaped graph...?
Thanks,
Rod
Write a Reply...
