I had an error mid session with obtaining images from the camera, i get a camera download error, a re-boot and power down seemed to of fixed it for the short term. But now its back and i cannot get rid of it. I have tried new drivers, older version drivers, new cables, 3 different PSU's (all good), Different laptop (windows), different apps such as NINA, APT, Sharpcap & the ASI suite. I have tried at least 3 different versions of NINA.
The errors are different with each app,
Some look like the visible over scan issue you used to get with some QHY cameras, Sharpcap is a weird blocky pattern, NINA is either cannot download or a Black image with white bar at top. ASI Suite looks ultra noisy with dark bands at the top, I have tested with only the camera attached and are still getting these issues. I think there could be a fault with the camera as this behavior has appeared out of no-where. I it has performed flawlessly for 2 months prior to this. My issue is similar to this https://theskysearchers.com/viewtopic.php?t=17088 I have downloaded the SDK can someone point me in the direction of instructions how to use so i can check logs for error codes.
