I have been using the asi294MC Pro for the past year and have had no problems. I thought that I would give the asi294MM a go. I use Sequence Generator Pro to capture the images. When I hooked up the mono I was able to capture the Northern Vale in Ha, SII and OIII. Due to the weather I was unable to get back out for a week. When I did get out the mono would not plate solve. It became unusable. No settings were changed. I reverted back to the color and it worked fine in SGP. Has anyone else experienced this with the ASI294MM PRO? Any suggestions?
