OK, tonight was the second time I really had a chance to use my new EAF. Hooked up all usb cables to the usual spots, powered up AAP and made WiFi conn to iPad. Tried to manual focus on Polaris so I could do PA, the focus control showed the setting was zero. Last time I used EAF it had focused and the setting showed 30000 something…now it’s on zero and if I tried to focus up or down it beeps about three or four times, the zero turns red and nothing happens, it doesn’t turn one tiny bit. I tried another usb cable, different usb connections ( 2.0 or 3.0), reset AAP, rebooted iPad. Lessened grub screw on focus knob of OTA and turned in inward about three turns, tightend grubs back up. Nothing changed, still stuck on zero and beeps several times, turns zero red and doesn’t do squat. This is about enough, right out of the box EAF wouldn’t power up from any usb connections on AAP. I had to buy usb hub to plug into just to get powered up. First night out it worked great! Now it’s a bad joke….
