Fid I have a LAN cable but only ever used it with a PC, can you use LAN with a tablet as there is no port.
Of course, at least with iOS.
Just get a Ethernet to Lightning adapter (older iPads) or Ethernet to USB-C adapter (newer iPads). When connected, the iOS Settings will show an Ethernet settings menu (just below the WiFi settings menu). You need to be careful with the Ethernet to Lightning adapter that can do 1000 Mbps; almost everything but one model on Amazon are the 10/100 Mbps varieties. Pretty much all Ethernet to USB-C adapters are capable of 1000/100/10, and will show as such in the iOS Ethernet settings.
There is no need to do anything special on ASIAIR -- ASIAIR uses Raspbian OS and Rasbian will automatically allow the ASIAIR app on iOS to talk to the ASIAIR box. You do need to give local network access on iOS to the ASIAIR app, but I assume you have already done that.
No free lunch in terms of Antenna Theory. High gain is only obtained by directivity. If you don't believe me, you can run an antenna modeling program that I had written (works only on MacOS and macos).
http://www.w7ay.net/site/Manuals/cocoaNEC/index.html
When the Raspberry Pi 4 version of ASIAIR first came out, I did a directivity sweep (by mounting ASIAIR on a remotely controlled alt-az mount) and it showed lots of very deep nulls (in the 30 decibel region). You should be able to find that post with a search of this forum.
My own ASIAIR is directly connected with Ethernet to an eero mesh router, with both inside a waterproof ABS box at the base of my semi-permanently sited tri-pier. As such , it is equivalent to being directly connected to my network, since I am connected directly to a mesh node.
While you are checking things, make sure you have a decent supply to the ASIAIR. If you are using the second generation ASIAIR, the voltage is not too critical, since it uses a buck converter to get the 5V that the Raspberry Pi needs. But current is very important. As a test, remove every device from the USB and power ports of the ASIAIR.
I don't know about the third generation.
I don't have a third generation ASIAIR since I do not trust ZWO to design something solid by themselves. I let guinea pigs like you stumble on the bugs (at least through one Winter), to figure if I can live with said bugs. I have two first gen ASIAIR (one being used 24x7 as an All Sky Camera) and two second gen ASIAIR; both of which are connected through Ethernet when in use. None of my ASIAIR are mounted on the OTA.
There is no evidence that ZWO had tested the ASIAIR in a cold chamber.
