How would you combine this Filter with image made with the ASI2600MC Pro Camera?
I use a single Luminance for the first set of images then change out the filter with the ZWO Duo-Band Narrowband filter using the ZWO Filter Drawer (M42).
I need to know how to set the filter settings to do this in any software but I am using MaxIm DL 6.
I select to first Luminance Stacked (RGB) Image and then the Duo-Band Narrowband Stacked Image.
The settings are for Hα (656.3nm)and OIII (500.7nm).
Do I add the Duo-Band Narrowband Stacked Image two times set one to 656.3nm and then the other to 500.7nm?
Or do I only Stack all images and not Combined with the Narrowband images?
So now I wonder if I should set the Camera to Mono when I use the "Duo-Band Filter" but then even doing this what settings would I use?
Or do I even Combined Narrowband Images and Color Images with this Camera?
Thank you for any help with this,
Bill (NoDarkSkies)
