MattyV So I need to make sure my mount matches my sidereal time right?
Correct, Matt. As long as LST agrees, or both UTC and Longitude agree, you should be good to go.
Another way to do a quick sanity check is first use a carpenter's level to level your mount/tripod in the east-west and north-south directions. Then look up a planetarium program (like Sky Safari) and use the mount's hand controller to move to an RA that is within a degree or so of the Meridian, and with a declination that is equal to your local Latitude. The same carpenter's level should show that the optical tube is pointed almost perfectly vertically at Zenith. If there is an east-west tilt, you have a time or longitude error, otherwise, you are again good to go.
Basically, the RA of a star is a fixed number, but the earth rotates and revolves around the Sun. 24 hours of sidereal duration (about 23 hrs 56 mins of wall clock time) is the time it takes for the star move to the same point that your mount is pointed at the next day. LST determines when the star crosses the Meridian -- a star transits across the Meridian when the LST precisely equal to the star's RA. So, that is the way the mount knows how far a star is east or west of the Meridian. If the LST of the mount is wrong, then the mount would move to the wrong place.
My tablet does have GPS on it but the time adjusts automatically with DST.
GPS chips output UTC. It then converts to Local Time using the UTC offset, and that offset is different by 1 hour between Summer (DST on) and Winter (DST off). If ZWO would just stop using local time and reference only to UTC, we wouldn't have all this confusion. It is a self inflicted wound by the programmers at ZWO.
So do I need to adjust the time on the tablet?
You should not have to touch the Location or Time services of your tablet's OS. Just turning off DST in the Mount should be sufficient to make the mount agree with ASIAIR's time.
