I have a CGEM II mount, which usually makes a quiet electrical whining sounds while it's on, which I understand to be typical. However, if I am powering the CGEM II through one of the ASIAir Plus' power outputs, the whining noise in the mount gets really loud as soon as I plug in the usb connection via the hand controller. The volume also increases (though not by as much) if I even just make metal to metal contact between the USB plug and port.
I have experimented with two different power supplies (both 12V, one 5A and the other 3A) and it happens with both. I also repeated while plugging in to outlets on separate circuits in my house for good measure.
However, this issue doesn't happen if I power the ASIAir Plus and the CGEM II with separate power supplies (under this condition, when I plug in the usb to the hand controller, I can tell that the electrical noise changes pitch slightly, but that's it).
I have seen mixed information about whether people are powering their mounts through the ASIAir power outputs. But given that this noise issue is happening then the mount isn't using a lot of power (ie, not slewing), I wonder if there may be a grounding issue with the unit.
What do you think?
