How do I install EAF to Sky-watcher Esprit 150 , what bracket do I need ? Thank you
Hello, You can refer to this link: https://www.yuque.com/zwopkb/hardware/eaf-support-list
hello , In this document it states that the Takahashi adaptor is not compatible with the Sky-watcher Esprit 150. Has ZWO revised the bracket dimension to accept the Esprit ? since the release of the document ? Thank you for your help .
otakar_g You will need the standard EAF motor bracket but can only fixed it with one screw, check pictures below.
