It would be very useful to be able to set the Gain value in Autorun, along with the already present Bin & Exposure Length.
I agree, this would be a good feature to add.
+1 from me
^ Agreed!
+1 . It makes perfect sense.
Or better… Add per filter gain settings so the gain changes automatically when you change filter.
willstones
willstones Or better… Add per filter gain settings so the gain changes automatically when you change filter.
Sorry, i don’t get it. Why would that be better? The tiles in the autorun settings already let you select the filter. What if i want to add several tiles with the same filter but with different gain settings? Then your solution would be very limiting.
willstones No thanks, just the initial request. Gain to Autorun. (You could add two tiles: One tile with your filter & Gain A, then another with Gain B if you wanted).
And while you’re doing that please as per filter focus offsets too! Thank you!
