As steve suggested, the manual rotation always works. But after your PA is dialied in. I reccomend disconnecting the mount and starting the connetion process over to the mount, to ensure you are at the home position.
AA+ has had limited compatibility with Celestron mounts. My CGX works fine in the last few builds and they updated teh bubble ? Help next to the mount with a new proceedure that doesn’t require any 1-star alignment, but in those cases it’s important you are set to home since the AA+ is using that as an assumption, if you are rotated manually all your goto will be off (from my experience).
