Hello,
I was able to connect the ASI120MC via the ASI294MCpro (hub port) and get it working on PHD2 as guidecam.
I needed to use the Flash update of the ASI120MC with the "ASI120MC-compatible.iic", and it worked.
But it doesn't work anymore, and I don't know how to fix it. Is there any solution to get the ASI120MC connected via the hubport of the ASI294MCpro ?
I really want to avoid the cost of buying the 120MM-S to get this solved :-(
All help is welcome
Rgds,
Koen
