Sure Joe;
step 1: power on AA+ With only your cameras, focuser, filter wheels connected. Everything but the mount
Step 2: connect to AA+ with the app from iphone/ipad, everything should be working except the mount
step 3: power on mount, set date, time, location, timezone, DST off
Step 4: move your mount to switches (or home), not sure if AVX has switches (I have CGX) but it should be perfectly vertical/centered, no rotation either. On the CGX, when I power it on it asks if it should move to switches, say yes. The mount should be pointing to Polaris roughly.
step 5: physically connect HC to AA+ via USB, turn the in-app switch to on which makes it connect to the mount
step 6: follow the prompt in AA+ app that pops up, I think it says something like do the quick align now
step 7: from the HC, do quick align, mount is all done at this point
step 8: click OK on the app to complete mount setup
I think that’s it but I’m going off memory so let me know if you see anything else.
If you do a goto, it should be really close, it will take picture, say it’s not centered, make minor adjustment and then it should be dead-centered.
Give that a try. Mounts pointing in wrong direction are because incorrect date/time/location/DST. Or the mount was NOT at switches (home) when it was connected to the AA+, this is important because I don’t think the AA+ actually reads coordinates from the mount, it assumes you are starting at switches, and it sends commands as needed.
