I found an issue with the beta ASPA experimental feature. There seems to be substantial difference in Where NCP is and the polar alignment. I am attaching two pictures that were taken only seconds apart. I ran the normal PA, didnt change anything, canceled the PA, turned on ASPA, ran PA again and you can see substantial differences in the total error. For each I refreshed 2x for a total of 3 measurements and they were very stable under both the PA & ASPA - so the variance is not in the seeing.
Shouldn’t these be really close? Is the original PA or ASPA more accurate?
