Markus Autofocus starts at pos 1940 (manual focus), it makes the first picture and then moves to max position 2800 makes the next pictures and tells me he can’t move anymore.
This may actually be the normal behavior ("normal" for ASIAIR, that is), Markus, depending on what you have set as the autofocusing step size in the (EAF) Focuser Setting window.
To get their focuser curve, the ASIAIR starts at an EAF setting far enough larger, so as to get an HFD of over 7 or 8 (I don't know the actual limit).
If, after moving to 2800, it is insufficient to get a large HFD, it then cannot proceed.
Change your EAF Max Step to something much larger than 2800. Try 5000 or 7000, for example. You can then look at where ASIAIR starts at, and in the future, if you want a small max step, reduce the max step to a delta a little more that the ASIAIR needs.
Your corrector may need a larger draw tube travel to get stars to show up with HFD of over 8.
