ckoos I also noticed that the AAP is shutting off tracking before a MF.
Tracking has to stop at the time of the meridian flip, otherwise the OTA will be crossing the Meridian without doing a pier flip, and potentially crashing the instrumentation into the pier.
However, the tracking needs to stop only after the ASIAIR has taken one last plate solving frame, to use later to confirm that the FOV has inverted after the flip. There are other ways to confirm a flip, but ZWO chose to look at camera angles, and thus need the plate solves. Self inflicted wound. Most mount protocols will even return the side of the pier the declination axis is located.
The bug probably is caused by the last plate not being taken before tracking stopped. That will cause streak in that plate and thus not recognize as parts of an asterism.
A regression test to confirm the precise choreography of an automatic meridian flip would have detected the bug.
The latest ASIAIR v1.9 TestFlight beta alludes to fixing an "AMF bug." I have no idea if the acronym refers to auto meridian flips; it might as well be talking about bowling balls.
If you are not a beta tester, try reducing the meridian flip exposure time. That will reduce the streaking and help make the stars be recognized as stars.
