Dear Support Team,
I connected an ASIAIR pro with a Celestron CPC925 (Alt-Az), two cameras (2600MMP and 174 mini), an EFW and an OAG (behind a reducer). I first aligned the scope through the hand controller, then connected the ASIAIR, and have proper control over the mount. Finding objects, plate solving and centering works.
However, calibration of guiding does not work, as there is no apparent movement in the stars (not hot pixels). All settings seem to be correct. I tried to change the timing parameters in the guide camera tab and experimented with basically everything possoble, but have not experienced any changes. I then tried to vary settings on the hand controller, without any change.
I would appreciate help in solving this issue! Thank you and best regards,
Klaus
(I previously worked successfully with the same ASIAIR pro, zwo asi cameras (2600MMP and 174 mini), and an EQ6-R Pro, and have used most features extensively. I believe I understand the functionality, and the firmware is updated.)
