@tech@zwo#54061
Hi, I submitted the logs using the address: xxx
In addition. I got so frustrated I brought the scope and all inside the house. I then bought a new power supply for the mount and tested it several days later. I was able to connect to the mount (from the ASIAir) and make adjustments, so the Plus was working at that time. With this in mind these are the things that changed:
1: I had no weight on the mount, usually there's about 40 pounds on it.
2: The temperature in my house is 64 degrees, where it has been around 15 outside.
3: Even though the USB cable I have been using is a new one, I used another one.
4: I used a new 12 volt power supply to the mount.
5: When the Plus failed to connect in the past, sometimes turning everything off and waiting worked, In this case I had everything off a couple days.
At the moment I seen the mount moving I thought the power might be a factor so I purchased an 8-port 12 volt power bank, which will arrive three days from now, over the weekend. This will replace all the power going to all the systems on the scope, ASIAir Plus, Camera, Mount etc...
I have also purchased an 8-port powered USB hub which I'll connect at the same time, over the weekend. It is a USB 3.0 hub and I thought I've heard ASIAir has issues with 3.0 on some things, but I'm hoping that isn't the case.
Or do think using all 3.0 would be an issue?
I'll be setting the scope up this weekend and trying out the additional stuff I've mentioned. If you could please review the logs to see if there's anything helpful, Also, please let me know if using 3.0 USB for all connections is okay, I'd sure appreciate it. I'll post here over the weekend with any updates.
I do thank you for your request for information. I've had this entire system for several months and most of that time I've been fighting to resolve mount-disconnect issues. Thank you!
Thank you,
LD
