The Flat73 lists a working back focus distance of 67.7mm. So with the EFW being 20mm and camera body 44mm you’ll need to find a T-ring that is thinner than (3.7mm +1/3 the filter thickness) instead of the standard 11mm. Then use your flatteners "adjustable" mechanism to dial in the back focus precisely. Would the camera even mount to the EFW if it’s that close?
Ps. I don't own any of this equipment, this is just my understanding of it.
