hello,
i have the same problem with my ASI 120mm on the sun,
this is a offset ,a very quick exposure and a AVI from 5 sec, with the optical tube closed
you can see the vertical line,
at first a using this offset in the processing, but the lines with always present on my sun picture
at last , i make a flat on the sun , i just defocalised the view, (diffuse) , and i using this flat in the processing, and it work fine !
sorry for my english, i'm french !
