@dhess62@hotmail.com#54384 I'm not sure what's going on. I think it all comes down to firmware.
Keep in mind that the ASIAIR does not really know how to perform a Meridian flip. You mount is the one that computes the motor's movement to perform the meridian flip when it discovers that the target is on the same side of the pier.
The ASIAIR simply sends a GOTO to the mount when it thinks the target has moved past the mount's meridian (i.e., target is now on the same side of the pier as the OTA).
After a meridian flip, the ASIAIR does a plate solve to confirm that a flip has occured. And it sends a Sync and GOTO if you had also set the "GoTo Auto-Center."
To get a meridian flip, followed immediately by another Meridian flip probably means that there is sufficent inconsistency between the ASIAIR plate solve and the mount's coodinates (i.e., if it is perfectly level, and perfectly polar aligned). After the first flip, the mount again thinks that the plate solved location shows that the OTA is again on the same side as its pier.
If you can't get your mount perfectly leveled and perfectly polar aligned, increase the "DO AMF x min after Meridian" parameter in the Meridian Flip Settings to compensate for any inaccuracy.
If you don't want to waste time waiting for the ASIAIR to issue a GOTO for the meridian flip, just level your mount accurately in the East-West direction, then do a good star alignment if your mount does not have an absolute encoder (or a relative encoder that is calibrated), and make sure polar alignment is precise.
You could of course avoid the double meridian flip by turning off auto-center.
For what its worth, ASIAIR could have avoided this double flipping if it had checked the pier side of the mount before issuing the auto-centering GOTO. But with my various experiments with my mount simulator, I have never seen the ASIAIR request the pier side from the mount.
For any given target, you should only get Meridian Flips that are 12 sidereal hours apart (two Meridian flips per day).
