I have ASI Air Pro (v 1.8.3/9.12)
The new function of All-Sky Polar Align is an amazing thing that really helps out my imaging sessions with Celestron AVX 8".
Below is a collection of issues that I am currently encountering:
Sometimes during the All-Sky Polar alighment the mount will not slew to the next part of the sky, although the corresponding message will be displayed. In such cases I restart the mount and start all over again.
After connecting the avx mount with asi air pro I am getting some strange initial RA values:
Shoud they be 24h 00m 00s for the celestial pole? And those numbers are changing in time. Why? And sometimes in DEC I get something like +89 degrees.
This is my routine of connecting my avx mount with asi air pro:
a) everything is switched off, mini usb is not plugged into the mount
b) switch on asi air pro and start the app
c) switch on the mount and perform quick align
d) plug in mini usb into the mount
e) choose Celestron AVX mount in app and connect. It shows then the message about performing the Quick Align which I have done previously
- For guiding assembly I am using ZWO 30F4 MiniScope with ZWO ASI 120MM mini.
In view mode I always see the bright stars as ovals of light instead of rounds.
When switching the mini camera as the main camera - the field of view looks pretty ok, all stars are round and bright.
