It may have saved the image file or files in the folder for the previous target, if that target was named. So if you viewed M42 just before the Rosette Nebula, look in the M42 folder. ASIAir uses, for bette4 or worse, a folder naming scheme based on target name.
By the way, you could use NGC 2244, the open cluster at the center of the nebula, or any of the NGC designations for parts of the nebula, for your go-to.
