@philippe barraud#54569 the slew is perfect but the plate-solve always fails
Plate Solve is not related to your mount, but to your telescope and camera.
What plate solve does is to take an image of the sky. Before the film days, this is making a glass photographic plate at the focus of a telescope; so the name "plate" has stuck with astronomers).
Asterisms (pattern of stars) are then generated for the stars that are seen in the FOV of the plate. These asterisms are then compared against a database of thousands of asterisms. Once the asterims on the plate match the asterisms in the database, the plate solve process can then locate the center of the FOV of the plate.
Think of it as a smart pattern matching process.
To get an asterisms of stars, you need to make sure there are enough stars available. Depending on the region of the sky, 25 stars may be sufficient, but about 100 detectable stars are prefereable.
The stars also need to look like points of light. Very defocus stars will be rejected.
You will need to carefully focus the telescope. And then set the exposure time to get sufficient stars.
With the ASIAIR, there is a Detect Stars in the Tools Menu icon of the Preview window (right under the Plate Solve menu icon). Take a preview image. Then tap on Detect Stars. That will tell you how many stars are detected and what the star sizes are. If the average star size is greater than 4 or 5, you need to focus better (unless you are very over-sampled -- in which case, plate solve will not work anyway).
Once you have enough stars in your FOV, to match the database of asterisms, your plate scale is important (how many arc seconds per pixel, which depends on the camer and the focal length of the telescope). ASIAIR knows the pixel size of your camera, so you just need to give it an accurate focal length to use. If you are unsure of the actual focal length of your telescope, set it to zero (yes, zero), and ASIAIR will make a more exhaustive search. It will take longer to solve when focal length is set to zero.
If Detect Star tool can see many stars, then check the focal length that you give to ASIAIR. Set it to zero if this is the first time you use ASIAIR, and do a plate solve. ASIAIR will fill in the correct number after a successul plate solve.
The same holds for the focal length of your guide scope. That needs to be correct too, otherwise, the autoguide steps will be completely wrong.
