FrankVa Can the ASIair be operated using Windows-based laptop as opposed to a tablet or phone?
Actually, you can. But as indicated by @stevesp you can only use an iOS or Android app. So you can install an Android emulator (BlueStacks is a popular one) and install the ASIAir app in that. Then you can control the ASIAir device via the ASIAir app on BlueStacks.
You can contro Asiair only with iOS or android app it works only with zwo devices (filter weel, motor focuser….) and some reflex it has power output 12v to power camera cooling and dew heaters it can control Celestron mounts (check supported list)
Many thanks!
Thanks so much -- will look into it!
