Can I use the ASIAIR Plus as a pass through USB to Ethernet router? It would be used similar to a Pegasus Astro Pocket Powerbox Advance.
it can not do this,can I ask what is your purpose?
To use N.I.N.A on a PC, instead of your SW. I want the WiFi connection, power and USB ports. Next gen should have power for Canon DSLR.
Next gen should also allow by pass of the SW other than setup, acting more like a Pegasus Powerbox.
