blang68 The WiFi signal is on and strong but I can not access it from the station mode which it was setup for or from the access point mode.
Did you give the ASIAIR app permission to access the Local Network on your iPad?
Check iOS Settings. On the left panel, scroll all the way down to the Applications group -- you should find the ASIAIR Setting there among the other Apps on your iPad (probably under the Apple Store App). Tap on the ASIAIR icon, and the right panel should show ASIAIR Settings. There are two setting that are critical; Location sevices (should be set to "While Using") and "Local Network" needs to be turned on. If you don't feel comfortable opening up those services to ZWO, you will not be able to use the ASIAIR.
The best way to update an ASIAIR is to connect the ASIAIR LAN port directly to the iPad (through Ethernet to Lightning adapter, or an Ethernet to USB-C adpater for a newer iPad Pro). Then turn on Ethernet in the iOS Settings (right under Wi-Fi settings, once you have an Ethernet adapter plugged in).
