Just obtained the above set up and would lke feedback on the following: With the above set up I get a pixel/image scale of 5.3, I assume that this leads to undersampling?? Presumably I should use binning to reduce this undersampling? I use SGPro do I simply set this to Bin 2x2 when taking the subs? Is this hardware or software binning? Feedback would be welcome.
