I thought I had this figured out, but the more I read the more I get confused. I have the Asiair Plus, ASI120MM Guide Camera , ZWO EAF, ASI2600MC. My swirl is the 2600 connections.
- What is the purpose of the 2600 USB 2.0 hub? Connect to the Guide camera? Does the 2600 “pass through” the guiding through the USB3.0 port to the ASAIR?
- I assume the USB 3.0 port connects to the ASIAIR.
- Does the USB 3.0 port provide the power necessary to run the cooler? Or do I need a separate power supply? I have a Pegasus Pocket Power micro that can provide a separate power source.
Thanks for the help
Bill
