maplearn
Hi there
Ok, the easiest way is to select your guide camera as the ‘Main Camera’, and then crack on using the focusing routine. Ensure you set your FL and Gain appropriately.
When you’re done, deselect the guide camera and re select your main camera as ‘Main Camera’ (ensuring the FL and Gain are set correctly).
Clear skies
Matt
