dean The Observatory is part of the National Radio Astronomy Network located in the National Radio Quiet Zone. The observing field rules state "no wireless devices".
Which is funny, since I read that there are now homes in Arbovale with WiFi :-). But yeah, you should observe radio silence all the way to Sugar Grove, even though I don't think the Navy has any listening equipment there any longer -- a Sputnik era thing.
I was at NRAO Green Bank for the summers of 1968 and 1969, as an NSF Undergraduate Fellow.
The skies are truly wonderful; you should see the meteor showers. Except for the strip mining, the entire West Virginia state is really beautiful country too.
Back when I was there, gasoline cars (spark plugs!) were not allowed past the gate to the radio telescopes. The observatory had specially modified diesel Dodge Darts (I think they were Darts, it was so long ago), and even they had specially shielded electric cables.
If I connect my iPad mini 6 to the ASIAIR+ ethernet port with the correct cable...RJ45 to USB-C
Yes, this will work just fine (IMHO, the fastest way to connect an iPad to an ASIAIR box). You can do this with both Lightning and USB-C iPads (I use both). With USB-C iPads, one of the dongles that I use is this:
https://www.amazon.com/gp/product/B00ZZ6NW5E
Bring along a 6 ft to 15 ft Ethernet cable. Test before you leave home. To also minimize RFI, use a shielded CAT6 if you can.
Once you connect to the dongle, an item called Ethernet will appear in the left column of the iOS Settings window (right below the WiFi settings).
There is nothing else you need to do. Raspbian will automatically connect to the LAN port, and the ASIAIR app will see the ASIAIR. With mine, the ASIAIR connected to IP address 169.254.232.xxx on the iPad.
The easiest way to disable a third generation ASIAIR WiFi from radiating is to use one of these 50 ohm SMA terminations in place of the antenna:
https://www.amazon.com/gp/product/B0719C1T99
Make sure you don't buy a shorting cap by mistake. They must be 50 ohms terminators. Don't leave the SMA antenna connector complelely empty either. A short and an open both present an infinite VSWR to the transmitter and not healthy to the transmitter unless it has full VSWR protection.
I have the above terminator permanently on my 3rd generation ASIAIR. I stay away from WiFi whenever I could.
BTW, connecting directly to a fast iPad can be additive. You may never use any other methods (even connected through home network) anymore. Downloads are definitely in the "augenblick" category :-).
(You can still find one of my reports in the NRAO archives:
https://www.gb.nrao.edu/electronics/edir/edir79.pdf :-)
Say hello to the Reber (you can't miss it, small cute 31-footer, painted red, white and blue :-), and Jansky (Bruce curtain, looks like a square wave with a reflector :-) antennas for me :-) Check the NRAO site map for Hannah House. That was the farm house where the summer students lived.
Pleasant memories from a lifetime ago. I was a Purdue EE undergrad then. After the second summer, I went to grad school at Stanford, and joined the Radar Astronomy group.
