Is there a way to move the prism up so it does not block the light to the sensor? With ASI's smaller OAG I can do it by loosing the screw bolt to move the prism.
kimama You can loosen this screw to adjust the prism position.
To tag along, can one use the OAG-L with the ASI1600mm( not pro) and 7 position FW? I’m using a focal reducer that requires 55mm back focus +1mm for filters so I need 56mm. My reducer is M48. If yes what would be the sequence?Thanks.
