The EAF will only let me have 60,000 steps, with all my different setups I need double if not triple that amount. Is there any way around the limitation?
Yes, simply reset the step count. Go from 0-60K, then set to 0 and go another 60K
Kring if I wanted to do that, I wouldn't be asking to expand the settings.
You asked for a workaround, that is the workaround.
I was hoping for a software fix, not one of my old farm boy baling wire fixes. I'm not even sure which language it's written in, I've been out of programming for quite a while.
