With apologies for duplication, I am re-posting part of a query from a thread under a different header; this header may be more suitable at this stage. As background: I'm using Zwo Asiair, version 4 FITS Liberator, Canon EOS camera (OSC).
... Continue to be perplexed about Fits Liberator. Have downloaded OSC FITS example files of unknown origin (probably NOT Zwo software) which open in FL; in these cases, FL shows 3 planes (RBG) in the pull down option. (None of which display with the 'checkerboard' pattern as might be expected.) This is not the case when I open my Zwo FIT files - FL shows only "Image 1, Plane 1". [Image overlain with a checkerboard pattern - assumption this has to do with Bayer patterning.] If I save from FL as a TIFF I get only a grayscale image. In response to comment concerning FITS header - yes, "BAYERPAT" = RGGB in the Zwo-generated files. So I should see 3 "planes" = channels, no? And, yes, a Windows operating environment. My overall goal is simply to generate a single RGB 16 bit TIFF from a Zwo FIT file, so I can set the FL issue aside if someone can give me precise directions for doing that using freeware. ... Thanks to all for help.
