It would be nice to be able to use the ASIAir app when the ASIAir is not powered on. Assuming the functionality of the ASIAir is in the app, and not on board the actual unit. If we could pre-plan things, set up things, do things in advance, it would be nice. Also using the "best of" feature before dusk would be nice.
ASIAIR Plus Offline Mode
@ZWO if you do look into this, would you combine it with the feature request for PROFILES or ability to save/export/import scope settings. In off-line mode it would be good to make changes to a scopes profile and settings so the next time it does come online the new settings will be used.
I agree that an offline mode would be really nice. The ability to make a Plan during the day without having to power up the rig would be super helpful.
Hmm. That's the thing, though. I think the ASIAIR App is literally just a "remote client" to what is on the ASIAIR itself. This is why you can connect to the ASIAIR with the App on one device, start things off , close the app, and the ASIAIR keeps on going. You can then connect with a totally different device running the ASIAIR App to check on things.
So not sure its possible. They would have to emulate the entire functionality of the ASIAIR within the App itself. Don't think that's possible.
