Hi, could you explain how to find vdB objects with the asiair? It doesn't find e.g. vdB150 (dark shark nebula)
Not sure if you can find those objects directly through the search in the ASIAir but you could look up the objects in Stellarium or SkySafari to get the coordinates then type them manually into the ASIAir and Go-To them.
