I am using an ASI 120 MM-S and ASIcap (v2.5.6) with SDK driver v3.17. When trying to change the offset (''brightness'') at constant commanded gain (30), I found the strange following results:
Since there is no reply nor comment, I just simplify my question: Everything seems to happen as if - in MONO16, BIN=1 or 2, and MONO8 BIN=1 : the binning was an average - in MONO8, BIN=2 : the binning was a sum. Is ZWO agreeing with that ?
alx https://astronomy-imaging-camera.com/tutorials/everything-you-need-to-know-about-astrophotography-pixel-binning-the-fundamentals.html Here is an article for your reference(fifth).
