Well the tilt adapter works! No more newton's rings! However I seem to be having a problem when it comes to taking flats with the PST. My previous method with the DMK31 was to place a translucent cap over the objective, increase exposure and shoot a flat. But for some reason this doesn't seem to work with the ASI120MM - instead it just seems to add noise to the final stacked image? I can't figure out why? So the full disc didn't work out. Seeing wasn't good either and the sun is very low here now at this latitude. So here are two HA shots, a prominece, and a CaK disc (which didn't require a flat). :)
