How does one tell when the camera has reached the set temperature in ASI image? It is easy to set, but there is no display of temperature as the camera cools down.
msw135 It is easy to set, but there is no display of temperature as the camera cools down.
On macOS, the temperature (and cooler power) info is in the title of the ASIImg window(!) Just stupid GUI -- violating all sorts of UI rules.
Thanks, did not know where to look.
msw135 did not know where to look.
Not your fault -- it should not be there in the first place.
Thank you for your feedback and support, we will continue to improve the user interface
