Here are some uncoloured solar shots in Ha and Cak with the ZWO ASI120MM. The solution to my previous flat frame problem is to shoot the centre of the defocused solar disc. The tilt adapter has successfully removed all trace of newton's rings, even with the powermate close up of AR11899. :)
