Check your power supply voltage.
The specs that ZWO published for the ASIAIR is bogus. The specs says the third generation ASIAIR works from 11V to 15V. It does not. I tested two of them and they (from the same manufacturing run) both refused to boot if the voltage is over 13.75 volts -- i.e., it will not boot on a fully charged lead acid battery.
