Hi I received a new AZEQ5 Pro mount and I have tried to connected it to new ASIAir Pro. With no luck. I use the same USB cable as for my EQ6R Pro which works fine (indeed I tried with both mounts powered up and simply took the USB out of the EQ6-R Pro and put it into the AZEQ5 Pro. In the EQ6-Pro everything connected fine, but with the AZEQ5 Pro, "Unconnected" appeared next to the Serial box and when I tried to toggle the switch on the EQMod device, I got "device on USB not recognised". Anyone know what's going on? Using ASIAir v1.9.
Thanks
Brian
