Hi Guys,
I have been using ASIAir for about 3 months and it is absolutely "GREAT", well done ZWO Team. The only persistant bug I have found is that after a Meridian Flip "ocassionaly" progess bar stops working and the captured images no longer download to the Screen, the indicator at the bottom of the screen says idle. If you look at the image folder the ASIAir is still capturing Lights and performing as it should. Most of the time the Meridian Flip is fine, this bug is intermittent, it doesn't happen all the time. At first I thought it might be due to using Bluestack on the Laptop, but I have since swapped to a Samsung Tablet, and the other night it happend on the Tablet. Maybe once out of every three to four Meridian flips this bug occurs. Has anyone else seen this problem? I'm using an EQDIR USB cable to interface the ASIAIR with a Skywatcher EQ8 Mount, and a Samsung Tablet, the combination works perfectly except fot that "one" bug. I have seen it on both my ASIAIR Pro and ASIAIR Plus. Cheers Peter
