@asiair@zwo#56387
Hi, thanks for your concern. EXP failure occurred no matter what it's lower than 1s and higher than 1s.
For others please refer to below;
And could you let me know in detail how I can use your link in Android and may I expect this update solve my problem?
Today I got a response from ZWO support team as follows;
Hi James,
I would recommend connecting to the ASIAir Plus via the ASIAir app, go into settings and reset the firmware. Delete the ASIAir app and reinstall it. This way you have a fresh copy and a fresh factory reset and updated firmware. We always recommend shutting down the ASIAir in the ASIAir app so it does not corrupt the OS or cause issues.
Clear skies,
And then I tested more and gave my feedback to them as follows; (looks like I am a test board^^)
Hi **,
I followed your steps one by one.
However even after I finished all your steps for the reset, I couldn't find any change explicitly shown in EMMC.
Two folders and some files I'd made, still exists there as it were, and one picture of ASIAIR Preview folder of EMMC from my previous test was still there.
So I am not sure whether I had a fresh factory reset from this job AS YOU SAID or not.
Anyway I could continue to do more test fortunately.
And one problem has been detected when I choose the option, "Save Image to DSLR Simultaneously" as shown in attached picture 1;
- If I use an external USB as the storage option, it works fine, in terms of this time testing.
But
If I use the internal EMMC as the storage option,
after I took one round of Autorun, any followed shooting in Preview or another Autorun never stopped, moreover I couldn't move to another menu of same category such as Preview, Autorun, Live, Focus etc.
So if I push on stop button to finish this exposure compulsorily, "Can't stop immediately, please wait for seconds" message came out as shown in attached picture 2, but it never stopped.
That's why I couldn't move to another menu.
And when I checked the status of Camera (Canon EOS R),
I couldn't switch to Play mode to see pictures taken, where the camera's LED message was "busy".
Even I tried to turned off Camera, Camera never turned off showing a message "On the way of saving remaining 2 pictures" as shown in attached picture 3, where however I can't figure out what 2 pictures are.
Only way I can get out of that status, was to showdown ASIAIR app, which made Camera turned off.
This situation did not happen in case of using an external USB as the storage option. I've tested 3 rounds of Preview and Autorun test.
I think other users might undergo same issues.
For the time being, I will do more test with an external USB as the storage option or not choosing the option, "Save Image to DSLR Simultaneously".
Please take care of this,
Regards,
James
