I thought it time to write an update on this issue. In the last 9 months I haven't pursued this issue as I have been busy with other tasks. Having now got my primary a.p. rig sorted out and productive, I have decided to get my "old" Losmandy G11 + Gemini 1 set up as a 2nd/backup rig. In the interim, the ASiair app has gone through a major upgrade.
I can report that ASiair app 2.1 connects to the G11/Gemini 1, and I am able to select a target and slew to it and track it. I'm awaiting a clear night so that I can run the gamut of activities (plate solving, focusing, polar alignment, guiding, image acquisition). The reason I am interested in pursuing the G11 is that it is more capable of working with my large refractor which weighs in at >16kg with everything installed and ready to go, than my primary mount.
Some notes that might be helpful for anyone trying to do similar:
- My G11 is >10 years old and runs vers. 1 of the Gemini system.
- The ASiair controls the Gem1 via a USB-Serial converter which appears in a PC's Device Manager as an 'ATEN USB to Serial Bridge (COMn)' under the Ports listing. The USB plug is connected to a USB 2 port on my ASiair Plus, the Serial cable plugs into the Gem1's 'RS-232' port.
- It is handy to load up the Gem1's configuration beforehand with relevant data (if you have not already done this at a previous session with the Gem1). I find that it works best if you start up the Gem1, select 'Warm restart?' on the HBX (hence the relevant data preload), then wait until the display goes blank. Now, start up the ASiair, and it should recognize the Losmandy G11 mount immediately. (If you start the ASiair too early, the Gem1 isn't in a state where it can respond to external connections.)
- Be aware that the Gem1/G11 needs to have at least 12V to operate successfully (13V+ is good!). I struck problems once the input voltage dropped below 11.8V.
I will report my success or otherwise once I have run the full suite of facilities. I'm hopeful that I can achieve similar guiding response to my primary rig, but we will see.
Clear skies, Paul.
