Hi everyone,
I'm having a hard time trying to control a Skywatcher AZ-EQ 5 mount in Alt-AZ mode through the app. I have connected it succesfully to Asiair with a Usb cable (bypassing the hc) and plate solved, but whatever driver I choose from the app (Eqmod, Skywatcher Alt-AZ) the GoTo function doesn't work correctly. It seems that the app mistakes the mount to be in EQ mode. I even tried to set the AZ mode from the HC firstly and then connect to Asiair, but no difference.
The only way I succeded slewing the mount correctly was by connecting the asiair to the HC, selecting SynScan in the App. But with this method after a couple of GoTOs the mount crushes and stops responding (and makes a terrible continuous noise like "STOP immediately whatever you are doing!").
Is there any solution to this?
Thanks in advance.
