Thank you, eastridingstars, for your prompt reply.
It is as I suspected: I will need a spacer between the camera and the T-ring adaptor. I have a set of these but whether there is one that is suitable is another question. I'll look at the camera specs and the T-ring I have and see what I need to make up the 44mm you mention. If I have to look elsewhere, your link should help nicely.
As I don't have the ASI183MC as yet (they are not due until July at my preferred supplier), it might be a while before I sort things out. When I do, I will post another reply spelling out my results for others to benefit.
cpl42
