Using an EFW mini on indi kstars 3.5.9 with driver indi_asi_efw. If the wheel is disconnected for any reason (which can happen, temporarily over a night), the driver will not recover. If I try to manually disconnect and reconnect it gives an error of device not found when calling openEFW(). The device is visible running lsusb in terminal.
The only way to reconnect is to stop and restart the entire indi server process. Other ZWO drivers like indi_asi_ccd will rediscover without needing this full restart. Is this something that can be implemented for the efw driver as well?
