Hello !
So far I've been using the ASI120MM only for planetary imaging, but now I'd like to use it as a guiding cam for deep sky photography since my old guiding cam produces too much noise to be of any use.
With my setup I have to use the guiding cam as ST4 relay (i.e. send the guiding signals via USB to the camera and from there via ST4 to my mount control box.
For guiding and imaging I'm using Astroart.
So which ASCOM drivers do I have to install for the ASI120MM to work as ST4 relay ?
I have already installed the ASICamera ASCOM Setup - do I have to install in addition the ASICamera ST4 Telescope ASCOM Setup or the USBST4 ASCOM Setup ?
Thanks a lot in advance and kind regards from Cologne, Germany !
Ingo Heide
PS: If Sam Wen should read this: Hi Sam, we've contacted already on the topic on FireCapture and the ASI120MM - now my ASI1200MM works fine with FireCapture. Have you heard of Torsten's heart attack and stay at the hospital ? Good luck to him that he recovers well !
