Hello, i hope i can get some advice, im loosing my nerves with this camera, i gonna throw it trough the window
i bought the camera brand new, its a few months old now (around 3) and since the second week it was been really annoying because it works sometimes and sometimes dont (Exposure failure). It is a totally random issue because sometimes it works perfectly and the morning the camera is dead.
the very first time this happened, i wasnt able to take any fotos with it, not even dark frames, and after two days, it began to work again... after a few days, this "exposure failure" error happened again, so i contacted the reseller, i handend the camera to them for checking and after two weeks they said the camera is working perfectly that they didnt found anything abnormal (maybe they just checked it one time and not exhaustively?) so i got it back... and after a few foto sessions, it died again:
it doesnt matter which cables i use (i tried several diferents cables) the connections are thight so no lose cables or whatsoever. im using a proper power supply for it, and sometimes powering via asiair it, but this is irrelevant because it wont work when it comes to that state. alls the drivers and softwares are the last versions availabe. Also it doesnt matter how i connect to the camera (i used Android tablets, apple tablets, Asiair plus software with last firmware and even the asistudio software) it wont budge. The cooling fan can be turned on and off, but ive noticed, that when the "exposure failure" error appears, the Asiair software doesnt show the correct temperature of the sensor. Lets say, i set the camera temperature in -10.0 C°, but theres no change in the temp. display in asiair plus (lower left corner) it just shows the ambient temperature and to the right theres a percentage number that changes gradually from 0% to 100%, but the temperature stays the same, even with the cooling fann full throttle, so it is unclear if it is cooling or not. the onlyt thing i only know is that i had problems with this camera since the very beginning.
The only solution until now its seems to leave the camera a few days whitout using it, and somehow magically it begins to work again, but thats really BS**T, the camera has to work when i need it. theres little info about this online, and im not wiling to send the camera everytime to repair, risking to be really damaged in the process. ITS VERY DISSAPOINTING
Esteban
